Rechargeble drill driver would be my go-to, but on hi torque low speed.
Definitely easiest option but it's something else to keep charged up?Rechargeble drill driver would be my go-to, but on hi torque low speed.
I don't think you realised I was talking about an electric tool, not a hand toolA 1/2" ratchet with suitable alen key socket would surely work a lot easier and more comfortable on the hands?
It is very handy to keep some kind of battery drill/driver in your motorhome. you never know when it can be useful. I use one to lower and raise the rear steadies - way quicker and easier than a hand tool. Then you can use the same tool to work on wheel nuts of changing a wheel. Maybe need the wheel tool to make the initial loosen depending on power of power tool, but once freed it can save time and effort.Definitely easiest option but it's something else to keep charged up?
No, I just quoted the wrong part of replyI don't think you realised I was talking about an electric tool, not a hand tool![]()
No! The socket for the Allen Key is covered by a plastic collar that slides to 1/3 open to give access to the key slot. A power tool and drive is an almost guaranteed way to ruin the mechanism. It's not designed to be raised/lowered, other than by battery power, and the 230Ah existing lithium is more than adequate for the job, provided that the solar can harvest adequately, hence the extra Solar Panel + Portable Panels.A 1/2" ratchet with suitable alen key socket would surely work a lot easier and more comfortable on the hands?
Unless you have a YoYo bed, a decent one will last ages, and you could always have a spare battery.Definitely easiest option but it's something else to keep charged up?
Post #46 above explains the frailty of the emergency hand crank tool - it's not really beefy enough to accept powered assistance and access is something you would only want to do in an emergency! More of a deterrent than a support mechanism! The bedding load once the bed frame and underbed 'lounge ceiling' is in situ is limited to 40kg max and the new Mattress is some 16.5kg. Add the weight of duvet, pillows and the bed ladder, and there's not a huge payload remaining - probably just about enough to allow for the Portable Solar Panel to be carried in transit if needed.It is very handy to keep some kind of battery drill/driver in your motorhome. you never know when it can be useful. I use one to lower and raise the rear steadies - way quicker and easier than a hand tool. Then you can use the same tool to work on wheel nuts of changing a wheel. Maybe need the wheel tool to make the initial loosen depending on power of power tool, but once freed it can save time and effort.
The bed is powered by the M/Home cabling which is wired to the Leisure Battery, and we don't have the space or payload to cart another 28Kg of standby battery for Mr Justin Case. The new installation should be adequate to give enough power to get through a couple of days with very limited solar, and enough solar panel harvesting capability to grab whatever the sun can generate to avoid the scraping of the barrel that we experienced in December!Unless you have a YoYo bed, a decent one will last ages, and you could always have a spare battery.
I think this is where strategic use of hookups, or a bit of extra driving sightseeing, can take the place of carrying around an extra battery just for the odd occasion you may need it due to inclement weather.The bed is powered by the M/Home cabling which is wired to the Leisure Battery, and we don't have the space or payload to cart another 28Kg of standby battery for Mr Justin Case. The new installation should be adequate to give enough power to get through a couple of days with very limited solar, and enough solar panel harvesting capability to grab whatever the sun can generate to avoid the scraping of the barrel that we experienced in December!
The switch can define what happens when you toggle it, but it is entirely up to you to decide why and when.I've had a look but can only see a facility to use cab battery when hab is low, which isnt really a wise idea.
Can't see anything to swop charge to cab battery from hab battery.
Why not just start the engine before winding the bed up or down?The bed is powered by the M/Home cabling which is wired to the Leisure Battery, and we don't have the space or payload to cart another 28Kg of standby battery for Mr Justin Case.
The change over from leisure battery to starter battery doesn't JUST govern which battery is being used for the habitation, it ALSO governs which battery gets charged from EHU too. Therefore if you switch to 'Vehicle, cab or starter ' and plug in EHU you'll charge the starter battery instead of the leisure battery.I've had a look but can only see a facility to use cab battery when hab is low, which isnt really a wise idea.
I certainly hope not.The switch can define what happens when you toggle it, but it is entirely up to you to decide why and when.
If you want to switch to using and charging the starter battery, do it. Nobody will die.
You learn something new every dayThat's not true for the Nordelettronica chargers, Stratto, they are bona fide chargers with adjustable absorbtion and float voltages.
Anything 200w or above will do and a decent MPPT if you need a good reliable feed. If it’s just a trickle Top up then 100w is fine and a cheapo controllerI am planning to fit solar panels but not got round to the research on what to fit yet.
I am very practical and good with hand and electrical work doesn't phase me but I've no great experience with Moho related stuff as last year was our 1st full year of ownership.
Moho also has a few angles to roof and 4 skylights and an aerial so I'm going to have to be clever with using the space available, but yeah SPs are def on the to do list.
