Does anyone know where to mount a bike rack on the rear wall please, this is a 2018 model and does not come with manufactured mounting point on the rear.
Elddis are not very help full, any help would be appreciated.
This is normally a factory-fitted accessory, not something Elddis will help you with.
Most large dealerships, like Brownhills in Newark, will gladly fit one on your Elddis .... but this can be expensive.
Look a bit ugly though!
On the rear of my Motorhome, the four fixing points on the rear have corresponding mounts on the inside with covers to hide the washers and nuts. I'd imagine a bike rack kit would come with those?
I've not tried this myself, but I would think you could use a stud finder to locate any prepared mounting points?
Seriously, I advise against it. The van's back wall isn't built to take the weight, and hanging on the back, bikes get filthy, are vulnerable to damage and theft.
As above ...... had a 2020 Eldiss with a Rack on the Rear that we never used & it needed a New Rear Wall in 2024 that come up with High Readings , was repaired under Warranty....... we got rid.
