TrevandJenny
Today I collected MH from storage with full intentions of removing factory fitted 80w panel and making ready to replace with the new 120w.
After getting up the wobbly ladder to the roof I found under the 80w panel a pair of MC4 connectors from panel wire to factory fitted wiring, Brilliant says I this saves loads of work can use this for new panel, However best check out inside.
The wiring from MC4 connectors went through the roof to a join, then twin wire to EC328 panel. My point, Victron panel wiring to MC4 connectors seems 2mm, Factory fitted twin wiring ( Round white household cable, brown & blue outer sleeves ) through roof to join seems 1mm, Twin auto wiring from join to EC328 panel 2mm.
Yes I am mechanical not electrical but. 2mm to 1mm to 2mm, factory fitted cant be right. I am ripping it out in the morning weather permitting.
