Ref battery to battery cable, I did say "SHOULD BE FUSED AT BOTH ENDS, unless they are right next to each other, in which case there should still be a fuse, but just one central one is ok. "So on the battery link cable I would place 2 100a fuses. A fuse before each battery positive terminal?
The cable is about 200mm long. I'm not sure there's space.
I will look for a midi fuse block. I'll have to work out what size fuses to get for each connection. I see in that image he has 100a on a 120a vsr, and 40a on a 30a solar controller. Yet the cables look to be the same size.
The krieger cables are really thick. The fuse is large also and I think it is 150a but I will check.
Fusing is confusing.
There is a minimum cable size, but not a maximum. I probably use 16mm2 cable on all the connections for convenience in that fusebox. You fuse to below the maximum current carrying ability of the cable and above the maximum continuous rating of the device. There are two aspects to the right cable. One is that it can carry the current and the other that you minimize the voltage drop.
For fuses, in the case of the VSR, we do not expect that Victron device to ever deliver close to the maximum 120A rating (that would mean around 3,000 Watts out the Alternator) so a cable that is rated at 110A was fine, but it meant we fused below that rating for safety.
Sounds like the Krieger cables may be decent then. That is good.
