I have the Sundance 630G and the middle bed is made up by first removing the table (simply lift up and it unhooks) and then pulling out the lats from the wall side and dropping them on the lips on the edge of the two bench seats. Then its a case of pulling the seat cushions forward and the backrests fill up the space created. This makes a 3/4 size bed.
Now, if you're asking how to make it in to the larger double bed (involving pulling out the side sliders then I'm at a loss as I've never been able to work that one out as well!!
I do have two pieces of foam in the garage section which I can only assume slot in to the gaps. I know the bench seats on both side have a wooden base so presumably you push these towards that sliding edge bit and use the foam fillers on the wall side?
