merl
It's a type of meter that can measure current in a cable simply by clamping the device around the cable. Ones that measure AC current can be had for less than £15 but you'll need one that measures DC current for the 12V system and they are more expensive typically £30 and up. It's easy to fall foul of dodgy advertising and receive an AC version even though you thought you were getting a DC version.I'll need to invest in a DC clamp then once I look up what one is. Thanks for advice.
The one Kev (pudey bear) linked to above is a decent device.
I can recommend a UNI-T UT210E
https://www.amazon.co.uk/dp/B00O1Q2HOQ?ref=emc_p_m_5_i_atc
It has a 2A range and is very sensitive and you can measure current's down to a few milliamps but it only goes up to 100A which is fine unless you want to measure large inverter currents over about 1Kw or so. They also do a 200A version for a few quid more
UNI-T UT210D
https://www.amazon.co.uk/dp/B0BJPH1WB5?ref=emc_p_m_5_i_atc
but I dont know if it has the same sensitivity as mine?
Here's a link to a clamp meter thread on WC
No excuses, you need one of these.
So, having answered many electrical queries and problems on here and posted several times about the necessity for motorhomers to own a DC clamp meter I thought I'd post info on this one which I've just took delivery of and cost me just £17.42 Inc postage, Mustool C21. I got it from Banggood...
