marchie
That's an Impressionist Show - 'Who do voodoo?'It's all voodoo to me , like inverters 12v in 240v out ????
Do you want something like this?Could anyone print me a Möbius strip? I want one for an ornament, so it should be around 15cm, and as it will be on display, it needs to look good.
fluid? are you looking for a strip that is fixed or you can actually move (like a tank track but with a twist in it for example?)I already did, twice, rubbish, you can't make it fluid.
The heater problems stems from it only being designed to heat a vans cab which would come with a bulkhead normally so Lees cubes than a car to keep warm the converters should ask for it to be uprated.
130bhp Ducato 2016, Kev, but built under a 5.99m coachbuilt Motorhome, so we've probably got more height in the hab area that needs heated. Once the cab area is heated, it stays quite warm, and we usually turn the hot air setting down to 60-70% after the first 40 miles or so, and then change back to 100% and increase the fan speed if we feel chilly, or if the internal temperature has fallen during a stop or similarYes, first thing it blows really well steve, its just shite distribution, what van do you have?
