4g LTE cat 6 Mobile router with antenna port
Hymer Snobs
I'm trying to source a 4g LTE+ cat 6 Mobile router with antenna port and powered via micro usb (or more to the point from a 12v USB port) and everything I've found doesn't tick all the boxes, ie it's cat 4, or UK plug or no antenna port;can anyone suggest a product that meets my need and for under £100? Thanks All
Why do you need Cat 6? This one TP Link will run off a 12v supply - I've done it with one of these 5v to 12v converter and a USB outlet.
The antennae can be unscrewed and replaced with an extrernal 4G aerial.
Cat 6 has signal amalgamation and gives 300 Mbps (potentially) as opposed to 150 for cat 4. When signals are poor the ability to amalgamate poor signals can be important.
Yes, but you are on a 4G network. Try and get 150mb/sec out of that. So the limitation is not the wifi, but the 4G signal.
Alan
I use one like this at home and away
powered with 240v to 12 v adaptor at home and one like this in the van
https://www.ebay.co.uk/itm/292798549234?var=592115829216
Does all I want from internet watch films, utube, catch up etc.
If req there is a antenna connection
How about this Teltonica, not cheap but very good especially if you're fulltime
I picked up A used dual sim RUT 950 off ebay year before last for £50....
Works a treat with a EE sim to go along with the 3 ones in our phones.
That was a bargain but he wants a Cat6 one and the RUT950 is only Cat4 ☹️
