Alde Heating
GMJ
Does anyone have this in their MH?
If so I'd welcome your thoughts on it's use and effectiveness.
Thanks
I had it in my previous van, a kontiki, and really liked it. It provided an even heat throughout the van even in -10C temperatures and didn't 'dry' the air.
Like any heating system, it needs to be designed well to cope with any demands placed on it, ie sufficient capacity to heat the space required.
Thanks
Did it require any on going maintenance? I have read about putting antifreeze in it?
Yes, it requires Alde heating fluid which has a life span of either two years or five years and contains antifreeze which needs changing. It's not a DIY job, at least not for me, the guy who did mine had a pump which would clean and then flush then replenish the system.
That's right as Tim120 said. I am a "qualified" Alde "technician" as I have been on the engineers training course. I used to be a Gas Safe registered "engineer". It's all just lego with pipes, gas and water / coolant. Personally I wouldn't want the Alde sysem in my camper, too much extra weight with all the coolant and radiators, on top of the servicing and maintenance costs. Think of your home central heating system: all the bits that go wrong with it are there in the Alde system. To me it is just another showroom bling thing, quite unnecessary when there are existing perfectly good heating systems, although the current combi boilers are not as good as the old Truma / Carver gas convectors. My camper has a diesel heater which is not as good as the original Carver convector heater and if I go anywhere with an electric supply I just plug in a 500W greenhouse heater. I use the diesel heater if there is no electric, but of course you use it if they are charging for it.
