saxonborg
If you don’t like using chemicals to clean the green algae from the roof of your motorhome then you could use the following:- if you have a steam wallpaper remover with an end which is just a a jet then the steam jet in conjunction with an aluminised pan scrub is perfect for removing the algae. You need a wet cloth to use immediately to wipe up the green water and detritus.
It worked for me.
It worked for me.
