Screenwash rubbed on neat with a tissue removes the adhesive for the Headlamp Beam Benders; don't know if it would work with Angles Morts though. Wash off with clear water just to be on the safe side?Removed stickers from MH, fair amount of adhesive residue still fixed to MH, what is best product to remove remainder of residue?
Cheers in advance![]()
Let it warm up in the sun if possible (or gently warm with a hair drier on low heat setting) then place a piece of tape over it and peel it straight off. The tape should pick off the softened adhesive after several goes at it and several fresh pieces of tape.Removed stickers from MH, fair amount of adhesive residue still fixed to MH, what is best product to remove remainder of residue?
Use the billions spent on roads which only increase traffic and pollution on safe cycling and walking routes so that walkers, cyclists, wheelers, people with prams, slow old ladies and men, people with zimmers can get about safely. And make sure everyone uses the Dutch Reach before opening a door, and stop drivers parking on pavements, and speeding .....I could go on....How do you remove cyclists who can't read?
Does it get them out of the grill too.Brake cleaner does it for me
Try “right turn Clyde”How do you remove cyclists who can't read?
