SimonM
Following on from a short while ago when I fitted a new MPPT and a solar controller and new batteries and now also a VSR (thanks for the advice Wildebus) I now have a slight voltage gauge question
All this lovely sunny weather and the solar panels are doing their job keeping the batteries topped up, and the extra volts are being crammed into the starter battery as well.
My NASA BM2 shows the leisure and the starter batteries at a regular 13.5v a completely separate voltmeter shows the starter at 13.5v, putting a voltmeter across the leisure batts shows 13.5v
The internal Burstner water and volts gauge shows the starter battery at 13.5v........
But it only shows the leisure batteries at 12v. .?????? I’d like an idea why? It has only started to do this in the past couple of days, it always showed the same as the solar previously.
Incidentally, if I turn the engine on all of the gauges show 14.4v as I’d expect, including the one which was previously showing 12v. It uses a Schaudt Elektroblok internal charger setup that the gauges take their info from. Suggestions please.
