runnach
Just fit a rubber gromit in the hole and use a reducer. You could try a main agent for the part.Looks like a reducer to me Terry, would a straight connector fit if the sizes are correct?
Gordon, the actual spray nozzles are located within the wiper arm itself. I guess this is so the water reaches where it is required within the screen area itself. A standard bottom of screen fit would be useless. Cheers............This is my set up solar panels
also this is in line washer pipe connectors
need make and model for other types terry
View attachment 65895View attachment 65896View attachment 65897
I will check them out GG, thank you for your help and input...............cheers.Try C A K , Kenilworth 01926 854271
It is called a BULK HEAD REDUCER If they can't help there supplier should have it, hope this helps
