rambrose
Got new front shocks, coils, spring caps and top mounts for my 08 citroen relay.
All from Autodoc using my reg to identify the parts.
This part of the top mount should sit inside the spring cap but it's a good mm too big.
There is a bearing and seal that goes in between. This protrusion is also tapered.
Am I right in thinking that the top mount should rotate on the spring cap?
The old stuff does.
The new spring caps are a little tighter on the old mounts.
Old spring caps won't fit the new mounts.
The new parts took a couple of weeks to arrive so I'm thinking of taking a file to the mount.
The old stuff does.
