OK.... carrying on with this thread, I got a reply from AutoTrail ...
"There where two lights which looked exactly the same that we fitted, one version had small screws down the centre finials where you have removed the screws out off. the other version was held in place by spring clips so will just pop out with a little pressure and care."
Shining the torch around the fitting didn't give me much more info. I tried putting a fine screwdriver into the "centre finials", but that was too small really - so any screwdriver that could have fitted I reckoned would be too small anyway. The things that looked like tabs do not actually connect to the fitting so they don't look like they would make a difference either. So I decided to go for plain force and used a trim removal tool to lever the fitting out without (hopefully!) damaging the veneer around the fitting.....
With some persuation the fitting was out!
So there were screws on the other side of the bezel in line with the centre finials. but they were not actually screwed into the ceiling - the hole was oversized so those screws were mostly just pushing against the side of the holes. Annoyingly there was some veneer chipped off
This is where it is a bit silly ... the reverse of the fitting:
The brass top bezel/cover locks to the fitting with two clips - one where the red arrow is and another deeper one on the opposite side. But there is no way to access that clip when the fitting is in place to separate it. Clearly it must have been clipped in after the fitting was put on?
Taking the bezel off reveals the screw heads
Way too big to have gone through the centre finials so must have been fitted and the bezel then put on as I suspected above. I have a reasonable collection of fine screwdrivers but not got anything that would have gone through that finial AND been enough to turn the screw.
So looks like the fitting is pretty well not removable without using levers and just pulling the screws through any wood they might have gone into.
I guess one option could be to have a drill bit though the finial and drill out the heads? that would release the fitting and then it could be refitted by turning the fitting so a new screw would avoid the old screw body. I think that is what I would do in future if I needed to remove one of these again.
But still not got anywhere with fitting the bulb yet
removed the two tiny screws that secure the reflector to the base and that allows access to the bulb receptacle. Unclippling this reveals the problem ....
something sticking out there - and with the receptacle in place that had nowhere to go and stayed blocking the hole
And as I suspected, it was a prong from an old bulb
could have just broke, or could have also been due to metal fatigue with the prongs heating and cooling over the years?
With that old prong removed and the reflector back in place, bulb goes in nice and normally
So ready to be refitted. Or is it?
There are two of these fittings in the bathroom and the bulb in the other fitting is flickering. So need a new bulb there for a start and wondering if I should change both fittings anyway? Could even sell the old ones to an Autotrail owner who needs a replacement as these are not available new any more!
