WildThingsKev
I've had the Votronic 45A b2b charger installed in our Rapido for 5 or 6 years now. It is activated by the D+ signal and charges 2 110Ah Victron gel batteries. I previously had a solar panel installed but when fitting the b2b I added a relay to isolate the solar output from the batteries to avoid them competing. In fact, I often manually isolate the solar from the batteries the night before moving so the b2b gets the true picture when it starts up for the morning drive. This is especially important for gel batteries where the "surface charge" can be quite different to the real state of charge because of the thicker plates.
With our use pattern I wouldn't bother with a solar panel again. We are in the alps for the next 2 months and even though today is bluebird the 80w panel would probably have output less than10Ah all day as the sun disappears behind a mountain at 3pm.
I wired in the b2b with new thick wires between both batteries for optimum charging and it always knocks out the full 45A for an hour or two after several days in the cold.
Ps, never even heard the cooling fan running.
