TrevandJenny
We have a 2017 Autosleeper Broadway with a Sargent EC328 electrician system. I removed the original 100amp lead acid battery in 2019 and replaced it with 2 x 100amp AGMs. Last year I removed the original 80watt Solar panel and replaced it with a 120 watt, the highest I could with the EC328.
The Sargent panel only shows voltage at the time the switch is pressed, either leisure or vehicle. As such I fitted a switched digital voltage reader direct from the leisure batteries.This shows a voltage normally .3 to .4v higher than the control panel as expected. The panel does not show any other electricial readings other than battery voltage.
As such I cannot see read any other values, Here the problem
We have been away for three weeks and I have noted a decline in voltage readings, Last night was our first on hook up for the last 6 days as being on THS sites As it’s been overcast in that time I realised poor solar harvesting was maybe the problem, In that time we had driven for an hour after a four night stopover, then the same after a two night stopover, We have now been on hook up for 16 hours and voltage still in the 13v range.
Main question is How do I tell the condition of the AGM leisure batteries?
