Steveandjulie
A lithium battery that allows 100% discharge should give same output as a pair of AGMs taken down to 50%, yes.
This point well made, and not just models with linked BMSesBe aware that if 100Ah doesn't prove to be enough storage (two or maybe three overcast days) you can't just add a second 100Ah lithium battery in parallel, unless you bought the more expensive sort that have BMS designed for linking.
Thanks for your reply very much appreciated still undecided as this camper isn't a forever van only till we retire then upgrade to a larger van.so would I be better off with the 2 AGM would they provide enough power for our needsA lithium battery that allows 100% discharge should give same output as a pair of AGMs taken down to 50%, yes.
In fact, it will be slightly better, as as the voltage of a battery drops, more current (amps) is drawn from the battery to deliver the same power (watts) - and while Lead Acid batteries drop in voltage as energy is used up, that effect is minimal on a Lithium until right at the end.
300W will run the compressor fridge no bother in the Summer. Come Autumn ... should be ok if not overcast all day![]()
you know, it could be worth going lithium still potentially, as in terms of service life, they could well outlive you (I think a new one will outlive me!) and you could take them with you to your new van, and you could drop in a brand new Lead Battery into the current van for the sale, which could be a good selling point?Thanks for your reply very much appreciated still undecided as this camper isn't a forever van only till we retire then upgrade to a larger van.so would I be better off with the 2 AGM would they provide enough power for our needs
That's a rather inaccurate description of the problem. Yes, the charge profile of an AGM battery is different and yes you can shorten its life dramatically by charging it wrongly. But it's utterly untrue to say that they require a higher charge rate. You can trickle-charge an AGM battery with impunity.Before you buy AGM batteries, make sure your charger has an AGM setting and alternator has enough output. They require a higher charge rate than lead acid batteries.
Our van came with AGM batteries and an AGM charger, but I had read many reports of AGM batteries failing if they weren't charged properly and the consensus ( from people that had them) is that they had a much shorter life than lead acid or gel.
I change mine for good quality lead acid batteries. ( Varta LFD90)
I was reliably informed by a company that makes AGM batteries that they require a higher charge rate than lead acid, I assume that’s why many chargers now have an AGM profile. Solar charging and long slow charging will work fine, but unless you regularly charge the battery fully, you will shorten its life.That's a rather inaccurate description of the problem. Yes, the charge profile of an AGM battery is different and yes you can shorten its life dramatically by charging it wrongly. But it's utterly untrue to say that they require a higher charge rate. You can trickle-charge an AGM battery with impunity.
My 100ah are 13kg each Baz, pair together are the weight of one of the Bosch 90ah they replaced. Gave me a nice 52kg weight savingHang around for a couple of months as alpha batterys are starting a new range of lifepo4 batterys about half the price of relion . Not that much more than 2 good agm batterys . In winter their will be times when 300 w won't be enough .you . did not mention heating .2 agm battery would weigh about 60 klg .lithiam less than 15 klg .
Ref ensuring long life by fully charging as soon as possible ... that is true of the large majority of lead acid batteries, not just AGM.I was reliably informed by a company that makes AGM batteries that they require a higher charge rate than lead acid, I assume that’s why many chargers now have an AGM profile. Solar charging and long slow charging will work fine, but unless you regularly charge the battery fully, you will shorten its life.
The handbook in my van ( with AGM profile on the charger and high output alternator) states that to ensure long life of the batteries, they should be fully charged after every trip using the built in charger.
My solar charger shows AGM batteries reach the absorption stage at 14.7v whereas lead acid only need to achieve 14.4v before the absorption stage starts.
Bosch and varta silver power frame are the best never mind the so called les batteriesThanks for all the advice will order 2 off alpha batteries
diesel heater ... assume 1.5Ah/per hour running x how many hours? 6? 8? you decide. Lets say 6 hours as an example.We have a sterling b2b charger and a smart charger from Aldi for when on hook up so both should work for lithium so seriously thinking of waiting for alpha to get the cheap lithium battery. Would one 100 amp be enough or best get 2?
We are hoping to fit a diesel heater soon as well as running a compressor fridge and a 12 volt TV in the evening
