marchie
We have tried to update in stages, using Brunhilde on a long'ish trip and then deciding what we would need to add/change to make the next long trip more successful/convenient. So most of the changes are in a chain. Had Gaslow x 2 fitted 13th July 2021, a 120Ah Lithium the following day [how to blow £1600 in 24 hours ...], then, via David @wildebus ,Ablemail AMT12-2 Battery Reconditioner + Ablemail B2B Charger in Jan 2022 [after the dreaded Airbag ECU failure that set us back just over £1300 including new ECU, reprogramming, new Vehicle Battery ['VB'] to replace the duff new VB after 7 days]. Added 2 x Ablemail ABB07 in April 2022 to enable the Ablemail App to report on SOC for the VB and LB to the phone and added a constant feed switch to the AMT12-2 to force the LB to charge the VB for 9 seconds in every 10. Then, back to @wildebus in late Septmber 2022 to add Victron Inverter and 4 sockets, including double socket in broom cupboard [or Ski Locker as Burstner describe it] for Bike Battery charging and outdoor cooking via Vango Induction Hob and Vango Folding Table.
After all that, we realised that our 'will only ever be lightly used' Inverter gets far more use than planned, so we will need to upgrade the Lithium LB and the Solar Panel to avoid the squeaky bum moments when even the Lithium pleads for mercy!
