Blocked drain tube ........... how do I clear it?
Dolomite Pete
I have an Autocruise Rythem and the tube that the bathroom sink drains through is partially blocked. The sink is one that hinges down, and the plug hole just empties into a black plastic chute with the tube running into the waist tank. Is it ok to use a chemical drain cleaner? I can't get a rod or wire into it. Has anyone else had this problem? I don't want to use bleach or anything that strong. Any ideas?
Many thanks
I wouldn't use wire or similar to poke down, it could get stuck or rupture the pipework.
If the bicarbonate of soda and vinegar doesn't work you could use Mr muscle drain cleaner, I've used it without any detrimental effects.
Not sure I'd use boiling water as I know someone who deformed their basin doing that - sorry to contradict someone's advice.
The cause will more than likely be hair mixed with the foul gungy muck that you always tend to get down these convoluted pipes.
Either of the above methods should effect results but if all else fails as it has in the past for me, I have used a length of flexible multi-core wiring cable that I have given a very rounded end to so that it won't damage the low quality pipes that I am afraid are always fitted to mega expensive professionally built vans.
And once you’ve cleared it, put hair traps on all your plug holes .... I could stuff a cushion from my hair loss after every shower!
We’ve a plunger on board ... worked for us, but I know it is not generally recommended.
If your going to use curtain wire. I would go with the eye end rather than a hook. If the hook catches on a pipe join it will be a pig of a job pulling it free.
Bicarbonate or cola would be my choice.
I use a 200mm piece of 25mm broom handle inside a 150mm piece of 25mm bore hose as a miniature plunger.Just fits over the drain outlet.
I don't know if all are the same but I unblocked one of those types of sink for a couple parked beside us and in their case it was just hair in a gauze at the sink joint seen with sink raised
This is a pretty common issue on camper vans and motorhomes, especially where the sink drains through a flexible chute into a waste tank. What usually happens is a mix of soap residue, grease, and sometimes hair builds up in that low-gradient pipe and slowly restricts flow.
I’d personally be cautious with strong chemical drain cleaners in this setup. A lot of RV plumbing uses softer plastics and glued joints, and aggressive chemicals can weaken seals over time or end up sitting in the waste tank causing more issues later.
A safer first approach is warm (not boiling) water mixed with a bit of dishwashing liquid. Pour it through slowly and repeat a few times. If you can, let it sit for 10–15 minutes to soften the blockage. Another good option is enzyme-based drain cleaners, which break down organic buildup without attacking the pipe material.
If you’re considering professional input or want to compare safe methods used in different regions, you might find it useful to check guidance from Plumber Singapore since they often deal with similar low-access drainage layouts in compact bathroom systems.
If access is limited and rods or wires aren’t an option, a wet/dry vacuum can sometimes work surprisingly well by sealing it at the sink outlet and pulling the blockage back instead of pushing it further down. I’ve seen this work on similar caravan setups where nothing else would reach.
One more thing, if the blockage is recurring, it might be worth checking the pipe run for a slight sag where debris collects, as that’s usually the root cause in these systems.
Possibly changed vans by now, but you're most welcome to the forum. We do our best to help and support other members and have a bit of fun at the same time. You get access to three different forums when you subscribe.
