Bluetooth Music Solution
WildCamper
I don't have the item linked below therefore can't comment through experience, but the item seems to offer a well priced, easily fitted solution for setting up a sound system in the rear of any van.
It works off 12V & the wattage is rated as RMS (as opposed to PMPO) therefore it should have plenty of volume available.
The item is a 12V powered bluetooth receiver with built in amplifier.
Once set up it will allow a cable free link to amplify & play music stored on any device with bluetooth (most commonly mobile 'phones).
Comments from anybody using said item or better alternatives welcomed.
Item:
https://www.ebay.co.uk/itm/E-Audio-...087774081&_trksid=p2047675.c100005.m1851#rwid
Alternative Source:
http://cpc.farnell.com/e-audio/b425...e&ddkey=http:en-CPC/CPC_United_Kingdom/search
Looks a nice bit of kit especially if you want to use your own speakers. I bought one of these and the sound quality is really good, I use it on my laptop when watching TV or a video and for listening to music from my iPod or mobile phone. You can also connect via a 3.5mm Stereo mini jack cable if your device isn't bluetooth
Regards,
Del
I've got fitted stereo speakers in the front and rear so have simply upgraded the sound system by installing a new head unit with bluetooth.It's possible to connect the laptop or smartphone and play downloaded music through the stereo system.I've just started using spotify so have plenty of music downloaded offline. If there is a decent data connection I can also use a radio app on the phone and play it through the stereo.
Regards,
Del
We have a very similar one. Can't remember the make...innotech?? Works really well and charges is usb which is useful.
Item:
Alternative Source:
I have a BOSE speaker that I can take anywhere in the van or outside, with the volume on the speaker and the volume on the tab turned right up it would blow your head off.
Bernie:Ok_Hand_Sign_Emoji::Ok_Hand_Sign_Emoji:
