Iandsm
On my Boxer, and I assume the Ducato is the same, l there is a small section of windscreen skuttle on the offside which can be removed to give access to the power steering reservoir. The removable part is held in place by three turn buttons. There are rubber seals which in theory stop rainwater gong through I not the engine compartment, the turn button fixings do not seal correctly and in heavy rain or if I pour water over the windscreen the water runs as to it should towards the main drain but as it passes over the removable part and over the turn buttons there is quite a bit of dripping. I have ensured the removable part is properly fixed and secured and that the turn buttons are locked in place but I cannot stop the drips. The water does not appear to drip on anything of any importance, it just runs down the inner wing and onto the top of the inner plastic wheel housing. I was wondering if anyone else had noticed this, it appears to be a design flaw, should I be concerned, does it matter, should I try to get it fixed. Thoughts appreciated please.
