Yes, that is true Andy n Mandy. There are, but I think not as many as the British makes. Last week I took a close look at the wiring in a German Globecar, and it did at least adhere to sensible, legal standards. See below the wiring in my AutoSleeper, wiring done by Sargent electrics trying and failing to stuff two 1.5mm wires into each pin designed to take one wire. Result: sparks, false alarms, fires, and at best sockets with no volts coming out of them. The only cure is to rewire the whole electrical system properly (which I did) but I imagine a dealer a) wouldn't do that job and b) if they did, they would charge ten hours labour. I think the going labour rate is about £100 / hour so you would have to pay £1000 just to rectify the manufacturer's faults. The Globecar I looked at used the same plugs and sockets, but correctly fitted one wire per pin.
Back to foreign ones: I had a Rapido with a sort-of similar fault where which ever 'I-couldn't-care-less' moron in the factory assembled the electric bed wiring MUST have seen that he hadn't correctly pushed an 8 pin plug and socket together, leavin one pin sticking out of the plug body. Brownhills failed to find this three times when I sent it back for fixing, they told me to contact Rapido in France, who told me to contact the bed manufacturer in Italy. They were brilliant, they send me the installation workshop manual for the bed and I was able to trace the fault and fix it. Why Brownhills couldn't, I don't know. I suspect their electrical operative was not given enough time to trace the fault. Or incompetent. One or the other. I won't be buying another Rapido or AutoSleeper - or any other make with Sargent electrics. Also below see the fire in the wardrobe caused by electric wiring aparently done by a 13 year old schoolboy on a Friday night after he had finished his homework.
