Carrerasax
Is it the two screws in the light lens that allow the whole thing to lift outIf it is demountable let it warm up to room temperature in your house. Then you could put in a bucket with some desiccant packs (silica gel beads) or cover with rice. Then enclose bucket with cling film. If your desiccant packs are old you can re-generate a wee bit by sticking on a warm radiator overnight. Hairdryer on a cool setting maybe. Slow drying rather than excess heat might do the trick. You might need to use a suitable glue to stop ingress in the future if you are successful in drying it out.
That would be my guessIs it the two screws in the light lens that allow the whole thing to lift out
Been away a few days. Sorry can't help with how to dismount. Just suggested some ways to dry it out that I have found successful. How did you get on?Is it the two screws in the light lens that allow the whole thing to lift out
Been a bit busy and not tried yet. Will get to it after the holidays. taBeen away a few days. Sorry can't help with how to dismount. Just suggested some ways to dry it out that I have found successful. How did you get on?
Re-prioritise.Been a bit busy and not tried yet. Will get to it after the holidays. ta
Is this reputable seems to involve change of 6 pin connector to 4So, removed offending camera today.
Looks pretty rough so think I’ll replace.
Seems to be residue of sone sort other than moisture on lower edge.
How is it best to secure a replacement. Seems a whole load of different types, pairs most of them. How do I make sure I get correct ones. Who’s best supplier in your experience?
View attachment 71068View attachment 71068
They are an excellent company to deal with (I have bought from them a couple of times and I would recommend them). The modern standard is 4 pin and you need an adaptor to fit a new camera to an older system. Give them a call and you will find them to be very helpful.Is this reputable seems to involve change of 6 pin connector to 4
https://www.parkingcameras.com/stor...-driving-camera-bundle-cab99m-cam222w-45.html
They were indeed very helpful but having got new cameras my dilemma is,They are an excellent company to deal with (I have bought from them a couple of times and I would recommend them). The modern standard is 4 pin and you need an adaptor to fit a new camera to an older system. Give them a call and you will find them to be very helpful.
Fitting the new bracket means drilling new holes which I’m not comfortable doing so I’d rather use just one of the original brackets if that will workI think the bracket is to reduce glare from the Sun more than anything. The camera is water resistant and that cover provides very little protection from rain. I would just leave it off.
