Not so much tired as well and truly lacquered, then, Jeff?I am busy doing a respray of Reg and Vals van at the mo Terry so I am not as lazy as you think i am lololol
I never ever said your were lazy Jeff, your missus Chris did.I am busy doing a respray of Reg and Vals van at the mo Terry so I am not as lazy as you think i am lololol
You doing this inside Jeff? For me spray painting is a black art.I am busy doing a respray of Reg and Vals van at the mo Terry so I am not as lazy as you think i am lololol
got to be over 40 years since i sprayed a car terry but its looking good so farYou doing this inside Jeff? For me spray painting is a black art.
First we had Banksy, now we have Jeffsygot to be over 40 years since i sprayed a car terry but its looking good so far
A Weegie attends Picasso's latest exhibition, but is not impressed, sniggering that the alleged masterpiece that everyone else is drooling over, is 'pure pish'. One of Picasso's Minders intervenes and tells the Weegie that unless he retracts his insulting appraisal, Picasso will put that smile on the other side of his face ...First we had Banksy, now we have Jeffsy
Trick is first use a good gun, binks 630 gravity is tops, less air and overspray, so all the paint goes on the job, small tricky bits use a iwata w71 side swival cup, or chinese copy, cost £10 or so.
Both guns are cheap one Trev but doing a decent job so far .Trick is first use a good gun, binks 630 gravity is tops, less air and overspray, so all the paint goes on the job, small tricky bits use a iwata w71 side swival cup, or chinese copy, cost £10 or so.
Doing the outside is bad enough Terry FFS lolololYou doing this inside Jeff? For me spray painting is a black art.
Smart DerrièreDoing the outside is bad enough Terry FFS lololol
At this time a bare motor, once fully restored to a mint condition, the Bentley will be a stunning vintage motor, not one that I can afford though!!good stuff
I don't know, Neil. I'll take a peek next time I am up there, bud.Does that one have an exposed flywheel in the cab Terry?
thats one neat bit of welding Terry.Job done, challenging was an understatement, lots of heat sinks where I could slot them in due to WAFER thin alloy did help.
1953 MK VI Bentley drop head ( soft top) all alloy, with difficult areas due to year of contamination ingrained into the material.
I like a challenge!!
View attachment 71583View attachment 71584View attachment 71585View attachment 71586View attachment 71587View attachment 71588View attachment 71589
Cheers Jeff, I can still lay them stack of dimes on decent material, a case of take what you get on old stuff. I had a choice of going MIG or TIG, I took the latter, which was a good call.thats one neat bit of welding Terry
