When speaking to certain folk, you soon find the wall is a far more attractive proposition
As an aside, and this is not something I would recommend however, the
Victron MPPT controller seems to work fine without a
battery attached! I found this out in an interesting way as I run my Habitation electrics THROUGH the LOAD output of a
Victron 100/20 MPPT. I do this as it allows me to both monitor and remotely control the power.
Back to the point, I was running stuff fine generally but the hab electrics would go off every night. Settings for Load output was set to "Always On" and could find no reason why this what happening and was totally discombobulated, and even posted a question on the
Victron Community site (where just occasionally you do get some useful feedback other then suggestions to try what you have already tried multiple times already).
But one reply made me realise the power was lost when it was dark, AND connection to the MPPT was also lost at the same time. Controller losing power when it lost
solar energy - which meant it had no
battery power of course!
On removal and careful examination I found a dry joint on the
Battery +ve, so the
Solar Controller and the
Battery had not been properly connected for around a month by the time I found this, and the MPPT Controller had been working like a power supply.
(I had checked the
battery connection a few times whilst troubleshooting, but the nature of a dry joint means the connection is often remade when you push on it, so the very action of putting meter probes firmly on the terminals 'fixed' the connection whilst being checked, so never found the problem that way
Victron sent me a replacement Controller and whilst waiting for it, I fixed the bad one anyway with a touch of solder and I had Hab power after dark
. But that repaired MPPT controller has been working without a problem for maybe 3 years, including maybe 2 years since I fixed it, with no adverse issues.
