Mobilvetta
Hi now we are back in the UK I thought I would empty the water tank and give it a good clean, on opening the inspection hatch I could not believe how much sand and debris there is in the tank. I have tried reading the instructions but cannot full empty the tank, I pulled a plug out from the top of a plastic extension, but is there away of also taking that extension out so that I can full drain it. I have put pictures up off the extension and the instructions, but I can't make Jean no tale of them. Once I do manage to get the tank fully empty, what would you suggest to use to clean the sand and bits out. Cannot believe all that dirt in the tank is from just 3 months use.
