Vanterrier
My shower-room basin Comet Florenz tap started to leak. Direct replacement was found here ( there maybe other, cheaper ones?)
So, picture of leaking tap for i.d.
Remove (destroy) small plastic blue/red cap to reveal screw
Remove handle to see
You can see one of three screws from here, but you need to carefully pull the spout outwards from the tower/cover and then gently prise off the chrome cover get access to the screws.
Now remove three screws and remove white plastic cover
Remove cartridge, mine is a Kerox 130712 according to stamps on the cartridge.
Reassembly should be a reverse of the above as they say.
Good luck
K
Cartridge for Comet Florenz tap | Comet taps | Leisureshopdirect
Buy a Cartridge for Comet Florenz tap | Comet taps | Leisureshopdirect
www.leisureshopdirect.com
Good luck
K
