Not sure that is 100% correct, damp manifest inside more as you might not see it at all outside.As the problem is on an internal wall I think we can rule out rendering and repointing as possible solutions.
Kev, we were advised to insert an airbrick in our single skin 'Barn' [English Estate Agent's description!] in France at head height, directly above the bottom airbrick to create a mini cyclone of air flow to eliminate damp. It buggered yp my new plasterboarding, but it did address the damp issue, and was better than having a damn great dehumidifier running full-timeNot sure that is 100% correct, damp manifest inside more as you might not see it at all outside.
Our lounge bay was damp last year so we looked outside and found a tiny crack in the cement joints on the stone sill so we re-did them and the dampness stopped, just simple water penetration like you might get in a van so also worth checking for.
Our back porch is on the north side and single stone skin it runs with damp even though it is ventilated with an air brick, and the boiler is in there too.
Any damp proofing company will use a resistance meter (designed for timber only) to assess moisture in plaster. They will diagnose rising damp.Pretty please can anyone reccomend a damp proofing company near Stratford on Avon. Unfortunately it's still an open door (me), rub hands (them), 'Oh look grey haired female..this will be easy!', world!
Ours does not, at least the expert could not find one, except he did find in one corner which looked like it might have been rebuilt what looked like a few pieces of slate which works well as a DPC.Every building already has a dampcourse and they don't wear out. Damp proofing is a con.
The problem with electrosmosis is that there is no credible way that it could possibly do what it claims. Damp doesn't rise in houses. The dampcourse fitted during construction doesn't leave home. All you need to do is not have leaks, overflowing gutters, gardens and paths banked up against walls, and with solid walls make sure it's lime plaster and lime mortar pointing.Our previous house was stone and rubble built also directly built on the ground. The walls were in the region of 3 foot thick. It cost us £30,000 in 1984 and we spend probably nearly £20,000 to bring it up to a decent standard which included new staircase, new partition walls (timber) upstairs, new windows, rewire, replumb, central heating, but also wet and dry rot treatment (30 year guarantee). All of the floors were fitted with plastic membrane sheeting before being relaid in concrete. The walls were stripped of plaster to a height of about 3 foot and then an electric osmosis system was installed.
A wire was embedded in the wall at about 12 -18 inches off floor level. It ran continuously round the inside of the outer wall and about every 3 to 6 feet (can’t properly remember) it was laid directly into a predrilled hole by around 6 inches (memory again). It was plugged into a 13 amp socket with a plug which greatly reduced the volts and was never switched off in the 35 years we lived there. The walls were replastered with a waterproof plaster.
Guaranteed for 25 or 30 years, we certainly had no damp issues, although like most houses we occasionally got condensation which was easily dealt with by opening windows, and very rarely we might get some mould in a dead air corner, again easily treated.
I think the the theory was that the ground was electrically negatively charged, but the building was positively charged (or the other way about) and the electric damp course brought the two elements into balance thus removing the potential for rising damp.
Worked well for the 35 years that we lived there.
Davy
A purchaser can seek compensation if know faults have been covered up and not disclosed.If I had some of the horror pictures on here in my home id paint it and put it o the market, some must be as old as the hills with single skin walls, all double here and full insulation, older homes are manly all knocked down or going to be soon.
