sydnsue
I am about to remove 2 leisure batteries for overwintering on a smart charger. I also have a 120W solar panel. Is it ok to just remove the batteries or do I need to do anything with the solar charger?
I'd just leave them connected if they get any sun they will assist the charger.
I am on the drive for 240V but all I read states the van charger and the solar are not as good as a smart charger.
I would agree with that if I was starting with a flat battery, but if the solar controller is a MPPT type they are pretty good it is of course what they were designed to do unlike most vans onboard chargers which are getting better but still fitted based on price, when I built my van I fitted a smart charger but I never turned it on except to test it, I had 2 x 110ah leisure batteries and the 100w solar panel kept them nicely topped up and also the starter battery via a fused link wire, I'm up in not so sunny West YorkshireI am on the drive for 240V but all I read states the van charger and the solar are not as good as a smart charger.
pudsey why not fit a switch and relay and use battery cable to join up, good point is you can use the switch/relay sys to jump start the van should the starter battery go low, my van is as so and very handy it is, on for driving and of when camping so not to discharge the starter batt.I would agree with that if I was starting with a flat battery, but if the solar controller is a MPPT type they are pretty good it is of course what they were designed to do unlike most vans onboard chargers which are getting better but still fitted based on price, when I built my van I fitted a smart charger but I never turned it on except to test it, I had 2 x 110ah leisure batteries and the 100w solar panel kept them nicely topped up and also the starter battery via a fused link wire, I'm up in not so sunny West Yorkshire
Over complicated.
Wrong Fred ??0 degrees but lots of sunshine and should remain dry.️
So simple to do.Over complicated.
DefinitelyWrong Fred ??
Thanks for everyone's advice but the facts have now changed. The twin batteries are suspect. Just tested them by running a headlight bulb after a full charge with a smart charger.
Battery 1.
Start voltage 13.06V.
12.05V after 5.5 hours.
Battery 2.
Start voltage 13.26V.
12.0V after 5.5 hours.
Would you agree these batteries are knackered? If the bulb is drawing 5A and the battery is 110AH, I reckon it should take 10 hours to reach 12V. Or am I doing something wrong?
