See if there is a bit of a "lump" between the Quadlock connector and the JVC Wiring. on Canbus setups, the ignition-on function on a separate connection on the vehicle loom side is replaced by Canbus tx+ and tx- signals (this is how the radio knows to shut down after 20 mins of whatever after the engine is turned off). most aftermarket radios use ISO connectons and not Canbus signals and so won't use that. the 'lump' is a canbus spoofer that makes an ignition-on +12V from the tx+ & tx- and Perm +ve, but using those are expensive (over £50) so are often not used and and alternatives used.Thanks for that. I’ll pull the radio tomorrow and see what goes where beyond the simple plug that I will have used.
I'd be interested what you have in place there. It sounds like Deltheffs have bypassed that auto-shutdown and I wonder if what you are seeing is a common problem but owners just haven't identified it on their vehicle if their normal MO is to do this?
