Extra hab door clamp/locks
Carrerasax
Are these worthwhile? Having had previous van door lock barrel punched out I think I may consider one but guess it’s A bit of a faff unlocking both.
anyone convinced they’re worth it?
I have them fitted and the few seconds extra to unlock them are worth it in my opinion, you will never make a motorhome thiefproof but making it more difficult than the one parked next to you is a good idea.
I have a Milenco Security door lock on the habitation door, the advantage with this one is that you can lock it from the inside
on the front door I have a Brightlock which is a cover that locks over the original handle, unfortunately no longer available
[h=3][/h]
I have a Fiamma D lock on my hab door which is mostly used as a grab handle for getting in and out of the MH however can easily be deployed as extra security when required.
I too am of the 'make mine harder to break into then the next one' school. I have extra Fiamma locks fitted to my external lockers (one key fits all three); Milenco window alarms; and Lock-Em-Out gizmo's on each window too.
I also carry a large Maglite torch as well...useful for seeing the way in the dark as well as other uses!
Graham
Graham
I too have one of these and find it a help to get in and out of the van and it gives me a bit more security.
Bernie
I have spent quite a lot on security over the years on caravans and motorhomes but never been targeted (touch wood). Not sure what this means though as it wasn’t all visible.
