merl
It's not a battery issue Kev, the battery gave you several attempts at starting and still kept turning the engine over and as you can see from your battery monitor the battery stayed above 11v during cranking which is acceptable. The fact it semi started briefly and then died and then started up later on with lots of black smoke would seem to me that it's fuel related but I'm no mechanic.
Isn't there a crank sensor that activates the fuel pump? If so could it be that?
Surely the fact that it's sat idle for a couple of months or so has got something to do with it? Could the fuel have drained back while it was standing and hence needed a load of cranking to get the fuel back up to the injectors.or high pressure pump? How does the fuel get to the high pressure pump? Electric pump? If so could it be that??
