hairydog
How much is it? We're on mains gas!I wish it were 50p a litre at 600 litres! think get stung a bit in the rurals (oooo doctor!)
Boats are a special case: LPG is tricky because a dropout hole is tricky.Wallis system very popular on boats .great idea for a self build ,no gas brilliant .
I paid just under 60p for 600L but I think if I get more will shop around much more aggresively (may move before more oil as summer use is very little.How much is it? We're on mains gas!
yes I got rid of gas on my boat and fitted a meths cooker bit slower than gas .I would be happy with a meths cooker in a self build .Boats are a special case: LPG is tricky because a dropout hole is tricky.
So LPG solutions are far less suitable for boats than they are for motorhomes,
Something that I don't think you have factored in for your price/kWh is the actual efficiency of the cooker in terms of Energy Transference.I can't find it sold in small quantities at less than £1 per litre.
Places like B&Q charge nearer £2 per litre, which is around 20p/KWh. Still a fifth of the price per KWh via batteries charged by free solar, but far more expensive than LPG or diesel
I am not skewing the numbers in any way whatsoever.But if you are quoting calculations like you have, to give a price per kWh, to make it valid you cannot ignore efficiencies of cooking methods OR say "heating the air is a bonus" to make it seem better. I could equally counter with "the gas is heating the air and I need to turn the fan up to increase air flow, which is an extra use of electricity that I wouldn't need to use otherwise". That comment is equally valid.
if you have an aversion to NOT using LPG that's fine, but don't skew the numbers to make your argument more valid otherwise all your numbers become very suspect.
Hmmm. I'd not even considered meths. Were you planning to use it for space and water heating as well as cooking?yes I got rid of gas on my boat and fitted a meths cooker bit slower than gas .I would be happy with a meths cooker in a self build .
most modern kettles have the element NOT in water in fact.I am not skewing the numbers in any way whatsoever.
The efficiency of any hob cooking fuel is more or less the same. Yes, an induction hob is marginally more efficient because no heat goes round the sides, but just as much goes through the sides. But it is less efficient than a jug kettle*.
The claims about induction hobs' much higher efficiency are mostly hogwash. Don't take my word for it: do a test.
Get three lots of 1 litre of water at a given temperature, then see how much power it takes to boil that one litre in a jug kettle, in a kettle on an induction hob and a kettle on a normal electric hob.
I'd be interested to see your results.
I appreciate that you can't do the test on gas because you don't have gas, but the actual heat source makes little difference: it'll be about the same efficiency as the conventional electric hob.
And yes, too narrow a pan and gas turned up up too high can waste more, but that's not what happens in the real world.
It seems to me that you decided that electricity is best and are only looking at "facts" that support your assertion.
For some people in some situations, electricity is indeed best, but in general, that is not true for the vast majority.
That's why all the high-end motorhomes have LPG-powered cooking and heating. And most of the non-high-end ones as well.
[later]
* Just realised that some people have jug kettles with the element underneath the floor of the kettle. I don't mean one of them: I mean the sort with the element inside the water being heated.
Speed is only an indicator of efficiency when other factors are equal. In this case, they are far from equal. And as you rightly point out, speed isn't always needed, or even desirablespeed can be an indication of efficiency.
I know when I use my 2kW induction hob to boil water in the camper, I actually set it at around 400W as otherwise by the time the teabag is in the mug and the milk and sugar ready the water would have all boiled away! (maybe that is an indication also of my own personal lack of efficiency and speed)
Gas is always easily available. Refilling is a bit tricky in the highlands of Scotland, but not really any where else. Bottles are available everywhere.money is always a factor when planning a conversation
But do not forget to factor in the ease of having no gas!
That’s your heating and cooking sorted. What will you do about refrigeration? 12 volt fridge and a big battery bank, plus 5-600 watts of solar?I'm revisiting this thread nearly 4 years later, now with an all-diesel campervan standing in the driveway.
It's a gas-free self-build Rifter conversion with a Wallas diesel hob which doubles as a hob for cooking with the lid raised or a heater with thermostat with the lid lowered. It's early days but so far very impressive performance and economical in use, especially when tested in the December chill at -9°C. Avoiding having to carry a heavy and bulky gas bottle is a huge advantage in a small vehicle and even more so now that gas bottles are not so easy to source.
