My son checks & services the Truma parts mentioned when he's carrying out a habitation for customers.The damp check is worthwhile !
But a decent damp meter maybe £50 SO
Diy amd repeat every 6 months.
£150 MAX
It is a check only so no repairs includes as wotj Mot only at £40
For gas call a suitable mobile person or go to a local moho garage..
Does anyone check and service the TRUMA water and air heating..probably not.
Biggest failure likely to be be the gas regulator..keep a spare !
I can only do damp checksWaste of money if out of warranty.
But that's just my opinion, fast as things pack up I repair and replace. Run round with damp meter every 6/12months .
Clean fridge burner once year check oven for blue flames fitted new jets and thermo cups.
We still under dealer warranty but have deside my repairs better than there's..
You can also check to flames are blue on the hob, grill and oven, that the fridge lights on gas, that it works on EHU, the the toilet flushes and doesn't leak, you ca n check the water heater works, and the blown air heater or fire lights quickly and gives heat, you can check if your leisure and starter batteries are charging, you can check for gas leaks with a spray can of detector fluid.I can only do damp checks
I know this has been discussed before so apologies.
How much would you pay for a hab check if like me you don't trust your own knowledge?
This morning I have been given quotes of £359 and £150. From experience I bet they both do the same checks.
Not surprised, who the hell put that together, doesn't look like a genuine joint anyway squashed pipe and a broken gland nut, it looks like leak spray in the background too, so the tech must have been blind.No smell of gas, owner unaware, picked up by my manometer in seconds
Similar to what my son charges and no VAT over and above.I have just had my habitation check carried out by
Convenient Caravan Solutions of Portsoy cost £150
A damp meter costs less than £20. Paying more gets you nothing extra. Agreed about two checks a year being a good idea.The damp check is worthwhile !
£150 MAX
