Help Burstner/ Fiat Ducato
I have the Diagnostics Report & the fault that was registered was'Brake & Accelerator Pedal Coherence ' so confirms the Posts on Fiat Forum about "Safety issue " so try not to touch both pedals on a Ducato Comformatic. 👍
Think that would show in Fault Codes also bring on Check Engine light which didn't happen I had no lights on Dash.
I could drive 50 miles or more with that 5” tear in the boost pipe without any code being generated or going into limp mode. You could see it if you looked in live dara with a code reader. No code doesn’t necessarily mean too much. Of course, it could be different on your vehicle
After the Diagnostics and the Faults being cleared, We have driven from the Midlands to Loch Lomand with no issues, I hope all is good now 👍
