TrevandJenny
I have now purchased a Victron mppt 75-15 smart solar controller as advised on this forum together with suitable cable fuses ect.
I unscrewed the Sargent 328 from the wall, removed the solar panel cable from the 328. I then looked at the Sargent display panel, scrolled through the menus and noticed that the panel was showing 2.2 amps input.
As I don’t want to cause damage I plugged the solar cable back into the 328.
I cannot understand why the panel was showing 2.2 amp with the cable to solar panel removed from the 328.
From the advice I have had on here, correct me if I am wrong
Fit Victron in place, install fused battery to controller cable to Victron, install solar to controller cable to Victron.
Is it safe to fit the upgraded Victron even though the Sargent visual screen is showing 2.2 amp, Help please. Thanks.
