Thanks for your reply , just a couple out so hopefully should be OKIf more than 50% work it should pass.
Have you a link or do you enter LED Strip lights ??Ebay has a some replacement strips, I've had to replace a couple they are usually Hella there is a number on the red lens search on Google as they can be cheap or expensive on eBay.
Thanks for thatGoogle Search
www.google.co.uk
Does the same apply to height level Side lights as well ?any bake light fitted must be working, if it doesnt light up it is a fail. However high level brake lights are treated as additional stop lamps - if its disconnected it will not fail.
If one is off, remove the bulb from the other one. My Tester never even noticed they were fitted.Does the same apply to height level Side lights as well ?
No .from my experienceDoes the same apply to height level Side lights as
