Hymer electrics
Peisinoe
Does anyone of an auto electrician in & around Leeds that works on motorhomes. Problem is not charging the leisure battery enough given we have 400w of solar & only charges 6amps at most. I need to get around the hymer system.
Might be better looking on MCEA to avoid complications.
I have a good one based in Bradford and another near Halifax the latter is better.
You mustn't listen to gossip from them there Lancashire hotpots.
Yup but them Lanky buggers spread shite rumours about us.
And why are you doing us down when you're nearly one of us anyway, bad form old chap, bad form ;) ;)
I had a 2015 Hymer Mercedes and had difficulty getting the leisure battery charged. Turned out it had a smart alternator but no booster/B2B. Other than that the electrics were very good with a proper 50A connection between the engine and leisure batteries.
50a cable seems low to me I think i had 25mm2 on mine over 1.5metres with 100a fuse
I was just moving off before management got the vapours again so just a quick reply.
