The engine will be fine so long as it has decent oil in it, If you want to run it, either make it for a few seconds merely to circulate the oil, 10 at the most or you build up heat and condensation, or take it for a good 30-minute run, the DPF should be fine but you could drop to third for a few minutes at 40mph, I always park in gear handbrake OFF on flat ground.
