Many thanksLoads on here... looks like they are recommended for higher pressures on commercial vans.
Loads of differing opinions too as usual.High Pressure Tyre Valves
The time is nigh for tyres to be replaced, I was looking at prices back in August and the Conti Vanco Camper was then £118 now £126! However I've been asking about having high pressure valves, what a performance this has been with very little knowledge out there or indeed willingness to provide t...forums.outandaboutlive.co.uk
K
Cause you are a big tube LOL.Never knowingly had a valve problem so never felt the need to look into it.
We had a Bush Rental TV around 1960. The local TV Repair Man, Mr Gibbs, visited most weeks to replace a valve; either that, or he fancied my mother ...Never knowingly had a valve problem so never felt the need to look into it.
Thank you for the info, looks like I have the lower pressure version fitted even though the max tyre pressures are 80psi for my tyres. I will be getting the rims refurbished in a few weeks so I can get the correct stems fitted then.There are two types of rubber valves, you can tell which you have by their appearance, normal low pressure valves found on cars are OK up to 65psi, high pressure valves are OK for 80psi or even 100psi, I have metal stems on mine but the high pressure valve rubber valve stems are more than adequate
You might to start enquiries now. I had Winter Tyres fitted in late February about 2 weeks before our trip to Europe, and couldn't find any Tyre Suppliers who could provide the high pressure valves on other than special order with a '2 or 3 week delivery, possibly longer ...'Thank you for the info, looks like I have the lower pressure version fitted even though the max tyre pressures are 80psi for my tyres. I will be getting the rims refurbished in a few weeks so I can get the correct stems fitted then.
The wheel refurbishing place have a lot of wheels in and they could only do mine the middle of July so given their turnover they might hold decent stocks of both types, I have to get in touch with them shortly so I will mention availability to them.You might to start enquiries now. I had Winter Tyres fitted in late February about 2 weeks before our trip to Europe, and couldn't find any Tyre Suppliers who could provide the high pressure valves on other than special order with a '2 or 3 week delivery, possibly longer ...'
I have Michelins fitted Neil but I don’t run them at their recommended pressures otherwise I would be bouncing off the cab roof.!Mine look like the low pressure valves as well (it’s what I thought they were anyway). I suppose I am lucky I can only fit Conti’s so if I stay with their recommended pressures I won’t have a problem. Seeing how high some folks run theirs though doesn’t it make it a rough/noisy ride?
