Barkwick
I have a 100 amp lithium battery and two 100 watt solar panels.
Can anyone suggest a suitable inverter please?
Which lithium battery do you have?I have a 100 amp lithium battery and two 100 watt solar panels.
Thank you.It totally depends on WHY you want an inverter?
The two pieces of advice I would give is, one, to go for a PURE SINE wave rather than a modified sine wave. They are much nearer to how mains works and will not damage the items you are running off it (in most cases!!). And two, use as thicker cable as you can and put the inverter as near to the battery as possible and then run a mains extension cable off this if you need to use it further away.
What size is preferable?Thank you.
