If you want the most efficient use of energy, you heat exactly the amount of water you need using an electric kettle or an induction hob.I think the point is being missed altogether.
Which one is the most efficient?
It you are washing up during the winter, then using a gas hob to heat a kettle is good as all the (considerable) wasted energy will go towards heating the interior of the motorhome.
If you are washing up in the summer, than you will use extra power to extract the unwanted heat and using electricity regenerated by solar is best. (The boiler heated by gas may seem more directed energy but it is still not that efficient, otherwise you would not get hot air out the extraction flue).
