forthpilot
Leisure batteries.
About to investigate leisure batteries,as they have started to not hold charge for more than two or three days, depending on use.
I know they are gel, because of the EBL99 settings, I realise I have to disconnect the panels from the solar charger, but it is well out of the
way under the driver's seat with difficult access. Given that the M/H is in shadow on the north side of the house, is it acceptable to cover
the panels rather than disconnect them. I can then follow normal the normal process to disconnect them and see what I have, as there
are no visible labels. The van is an older Hymer B510 with two batteries in an underfloor locker, and I strongly suspect that they are
Exide G80's. favoured by hymer, but I want to check before I order replacements.
Stewart
Stewart
