dogsbarker
My tank is 20KG and I find that ok my problem is finding a garage that sells it!!The savings from refillable bottles or a tank are not just down to the cost of the gas.
From an autogas pump, it costs between 90p and £1.80 per KG. That's a very wide variation in price for the same thing!
With a refillable, you can shop around and top up whenever you pass a cheap supply*.
You can't do that with exchange cylinders: you have to wait till you have an empty bottle to swap, or you have to give away the gas that was left.
Unless you wait for a bottle to completely run out before changing it, you always do lose the bit that was left.
Never mind the cost, it is so much easier to top up than to run out and swap.
*Of course, with a bigger tank, you have more scope for doing that. Our tank holds 28KG of LPG. Don't think I'd really want a smaller one for some trips.
