In all honesty, I don't agree with everything that's been said.
Surely the key thing about leaving the van plugged in is to make sure it's using a smart charger. Mobilvetta, your van is brand new isn't it, so it's very likely to have an up-to-date smart charger... check with the supplier if you're not sure. As I understand it, a smart charger keeps the batteries maintained in excellent health by cycling through raising and lowering the amount of power it's pushing into the batteries, according to need.
You didn't say if you have a
solar panel or not. If not, then leaving the van standing without power for a few weeks could likely mean that your engine
battery will go flat. This happened to me a few times when I first got my 2nd-hand motorhome and was the top reason for having
solar installed. Far better to keep the van plugged in then. Worth checking with your paperwork or the supplier to make sure your system is charging the engine
battery as well as the leisure one(s), although it sounds very likely from your panel readings. I'm definitely no expert and hope the electrickery wizards will correct me if I'm wrong... but I think what you're checking for is something along the lines of '
battery to
battery' charger, 'split relay' or 'MPPT' controller. Anyone?
As for the winter, I too use a low wattage heater in the van, set just to take the chill off. Mike is probably right about lots of vans in storage just sitting there without power but a few years back, pre- the heater, I used moisture traps in the van... they produced pints and pints of trapped moisture out of the air in the winter. Far better IMHO to use a low powered heater on thermostat. I never leave water in my van between trips anyway but I'd definitely drain it out in the winter. The boiler is a really expensive bit of kit, so best to pre-empt a problem and empty it rather than risk is freezing... my thinking anyway. I also empty my fridge after each trip, turn it off and leave both the door and freezer section propped open with something. No need to leave electrical equipment running up your bills unnecessarily and switching everything off will save wear and tear too.
Every motorhomer will have a different idea of how things should be done... no-one's 100% wrong or right - just different preferences and what works best for your particular van, so it's good to get a cross section of views and take your pick
Enjoy your lovely new motorhome!
