Cowie
Am I entitled to my money back if a new van is faulty. First time setting of for home after delivery and entering the A1 motorway the van lost complete power. Phoned the dealer and was told I must have pressed the brake and accelerator at the same time. Happened again on the A9. Reported the fault again and was told to book the van into a Fiat dealership garage. They replaced a brake switch and said problem solved. Next time on the A96 same thing happened complete loss of power. Bearing in mind these are busy roads and could have caused serious injury to myself and others it was pretty traumatic. Also the passenger door has to be excessively banged closed to shut offthe bleeping on the dashboard saying door not closed. Also when going over a bump in the road it will start bleeping again saying passenger door not closed. Also there is wind howling through the door as though the window was down. Phoned the dealer and took it to the company they recommended as we are a good distance from the dealer. The technicians looked at the door and said they could see daylight at the bottom of the door and said the door was bowed. They couldn’t do nothing to fix. I’ve lost confidence to drive this van. Am I entitled to my money back. Disappointed as I thought I’d bought a quality van.(Frankia SD)
