Won’t be any room Jeff once you drop yon tank inLovely bit of kit .
Loved my imp wullyI knew a guy who raced and built Hillman Imps remember he once had a v8 rover engine in one.
I agree Trev but if they were straight you wouldn't be able to see over the bonnet, plus the fact that HIF44 SU carbs are no good at 45% angles, the maximum angle for a SU is 30%, even with the original CD Stromberg carburettors (Jaguar didn't fit SU carburettors so these are an aftermarket upgrade) which aren't as tall as SU's they would still be too high.Big problem with the inlets and the bends which causes gas/fuel condensing at the corners of the bends, inlet tracts should be straight and at about 45% to the valve, ok if it was direct fuel injection into the cylinders, not with su carbs.
