Yes it does. This is the reason why you have to use pretty heavy cable when installing a Compressor fridge even though it only draws around 4A when running.Does a pure 12v compressor fridge do the same though? I could get mine to run on 240v by fitting a Mobilec 100W rectifier, the initial surge isn’t the charging of the rectifier is it?
And the reason why so many people find their fridge won't start up due to low voltage even though their battery is perfectly fine because the installer looked at the specs and used cable which is fine for the running current and not the surge.
