Just had a welding job done on mine the guy wax oiled it all in the priceAdvice please. Took van for an estimate yesterday re the welding. Guy suggested oiling the under side of van because of salt corrosion. He has a van himself.
Thoughts please. Ta
Have a look at a rust preventative called Lanoguard, it contains lanolin and is becoming a popular alternative to Waxoil and similar treatments, easy to apply yourself as well.Advice please. Took van for an estimate yesterday re the welding. Guy suggested oiling the under side of van because of salt corrosion. He has a van himself.
Thoughts please. Ta
I've used lanoguard Eric and I thinks it's a good product as long as you recoat it ever year.Have a look at a rust preventative called Lanoguard, it contains lanolin and is becoming a popular alternative to Waxoil and similar treatments, easy to apply yourself as well.
Unfortunately no one tells you this stuff and ignorance is not always good.Any rust must be removed first, then tratment to stop water/salt corrosion,its not just the underside but internal parts like doors sills and a frame around the door, most of this should be done from new, gate horse and bolt spring to mind.
Water coming in being dealt with asap. The guys are very busy at presentWith the water coming in from above and the oil sprayed on your bottom the oil slick with be like a breadcrumb trail
First priority is get the van watertight if your clothes and bedding make you I’ll because they are damp the van will be unpleasant to use so repair the top before treating the bottom
Don't we all lololThese are times when I wish I was 10 years younger!
